1 - 13 of 13 Posts
I am working on 3 linking my 01 z71 and i have a couple of questions(yes i Searched)
1.)How to find the Sprung Mass Center of Gravity?
2.)How long should i make the lower links (Pretty much as long as i can without bind)and then the upper is supposed to be 70% of the lowers correct?
3.)Can the lower links be perpendicular to the axle or should they be triangulated?
4.)Does any one know if a 1979 bronco coil will fit into this bucket for coils up to 5.75" wide
Any help will be gratefully appreciated
Bring On The Burn
im in the middle of getting going on swapping a solid into my 07 classic,
using cage radius arms, ballistic adjustble brackets on the frame "ame as you posted" and the coils from cage since the price is right.
from my reading yes the bronco coils will sit in there nice and happy, call up Nate at ballistic and confirm.
-shawn
· Premium Member
-shawn
Lets see this build man!
that tube will be plenty strong. I didnt even use that thick - only .25 wall. The 2.25 OD should make it sufficiant.
I can get some numbers for you next week. I did my first test drive today (on the road at least) and am loving it. Im running roughly 60% anti-dive with a very flat roll axis.
Discussion Starter · #9 ·
Are we talking about an SAS front 3 link with panhard or a wishbone style 3 link in the rear?
front 3-link with panhard
nice number would be cool so i can get an idea. also any close up pictures of the links would be great if u dont mind
plan is to start the tear down next weekend,
trying to find a dana 60 local in the mean time to avod using the 44, but i'll do what I gotta do .
mine is a 2wd, so using stock tranny output, spacer/adapeter twin sticked pass drop 205 and pass drop axel.
ill post pics when I start burning some metal.
Discussion Starter · #11 ·
Got the tape measure out tonight and figured out where i think i want my links to go. Not to sure on the " Sprung Mass CG 'Z' " I know it effects the Anti-Squat but this is what i have so far, Let me Know what you guys think.
1 - 13 of 13 Posts
