1461 - 1480 of 1572 Posts
E-Locker or Bust!
Discussion Starter #1,461 (Edited)
Got the springs squared away last night.
Looking at the amount of arch between the old and new spring (not in the picture, I measured the old pack after putting it back together), there's approximately 1" more arch in the new springs.
Old:
Spring rate: 227.07 lb/in
Squat = 7.49"
-2" block
Total = 5.49"
New pack (4 Leaves):
Spring rate: 250.7 lb/in - Squat = 6.78"
-0.7" zero rate
-1" additional arch
Total Squat= 5.08"​
Height compared to previous setup = 5.49" - 5.08" = +0.41"
Thus, if they squat as much as my calculations suggest, I'll actually end up a smidge higher than I was on the old springs. I can ditch the 3/4" "zero rate" (AKA cut down overload spring) to drop it down if it ends up higher than I calculated. Sorry if I'm boring you all with math... this is the stuff I enjoy :flipoff2:
Now just waiting on new shackle bushings because the sleeves on my old ones were a solid hit away from crumbling due to rust.
Speaking of which... Does anyone know of a OE-application rubber bushing that would press into 1.75" ID DOM that's 2.5" wide and has a 3" sleeve? Similar to what you'd press into a leaf spring eye. I'd like to ditch these poly bushings if possible because they only seem to last like 2 salty Illinois winters before being unusable. Greasable ones help, but that still seems to only prolong the life another year or two.
If you can't get the bushings you're looking for, try marine grease on whatever you do toss in there. It works great up here in NH with all the salt and weather we see. The BRP brand is called Triple Guard and the grease gun tube is PN 775776.
I second this.
Since switching to marine grease 3 years ago i haven't had to replace a u-joint, rod end, or bearing..... or even repack front wheel bearings.
E-Locker or Bust!
Discussion Starter #1,464 (Edited)
Will do. You run marine grease in the wheel bearings too? No issues with it overheating?
I will say that the Energy suspension bushings I replaced these with have a seemingly solid (no visible weld seam) sleeve and are yellow-zinc plated. I don't think the old ones were. So these ought to last longer. I used the provided energy suspension grease which is super tacky (like marine grease), so again - these will probably last longer.
Still, I've gone 5-6 years on my front springs before I needed to replace the rubber bushings and it wasn't due to rust - they had just finally worn out due to all the flexing and whatnot. I'd much prefer a rubber bushing on my leaf spring shackle if at all possible.
I got the truck back together last night. Ended up taking out the cut-down overload from the pack since the rear measured higher than the front hub to fender when I set it down on jack stands. Didn't get a level-ground measurement, but it looks close to where it was before.
Yesterday on my lunch break, I went down the rabbit hole of leaf spring slider boxes for the next iteration of my rear suspension. I'm seriously considering this route, now. Looks like a lot of people have good luck with these even on a street-driven rig. The biggest thing would be making sure to plate the bottom of the slider box so that they don't get damaged coming down on them off-road, but that should be no problem. They'd be a fully custom design if I go this route so I can run really beefy UHMW sliders (or upgrade to bronze if those don't last long enough). It started out as a brain exercise but now I'm really liking this as an option.
Leaf spring sliders are cool. I actually built a set im not likely going to use. Super beefy, and i doubt I'd damage them if i landed on them. I'll post pics when i get into the shop again.
Truck's looking really good. Glad you're actually enjoying using it.
E-Locker or Bust!
Discussion Starter #1,467 (Edited)
Would love to see pictures. I haven't started drawing anything up, but will probably over the weekend if the weather is crappy.
Are you wanting spring sliders front, rear, or both?
Only on the rear when I move to Deavers or Alcan springs. Front would be really difficult to package and if I'm trying to hold off redoing the front suspension until I one-day link it w/ coilovers (years in the future due to cost).
I second this.
Good feedback. I was going to start doing some maintenance items soon, like pulling apart my hubs and packing the front bearings, and the use of marine grease keeps popping in my mind.
I enjoy the leaf spring tech of spring rates! I enjoy any of that odd tech...Looking good as always.
I have never been sold on slider boxes. What is the actual benefit to them?
E-Locker or Bust!
Discussion Starter #1,470
More lateral stability (especially on the road) and more linear/controlled spring rate modification than shackles. Since the shackles move in an arc, they affect the spring rate of the leaf spring as it changes from arched to flat and vice-versa. Slider boxes don't do this at all.
For my application, they also yield a better departure angle than a tension shackle and essentially the same departure angle as with compression shackles (since the spring eye is more or less the lowest point).
I'm still not fully sold on going this route, but it's worth exploring or maybe even trying out. I have a line on some 3" lift Alcan springs used from someone, which aren't quite arched enough for a tension shackle, but would be a good candidate for a slider box (or compression shackle setup).
E-Locker or Bust!
Discussion Starter #1,471 (Edited)
After getting the leaf springs installed and some friendly ribbing from @BigLBZPower08 , I got a wild hair about installing the Custom/Prototype WFO Sway Bar I've had for over 5 years (!!) that they pulled off a GMT400 they were parting out.
It's a splined torsion bar style (like Currie) with clamp-on thick arms and uses UHMW bushings at each end of a tube to support the torsion bar. In the interest of saving weight, I didn't see the point in running a tube across the frame to support only the ends of the torsion bar, so I found some 1.5" and used it as an alignment bar. I calculate around 5lbs saved by eliminating the material between the mounts.
I also determined that due to my shock hoop design that the straight arms wouldn't clear no matter what I did, and I figured out that bent arms would work quite well.
I tried bending them with my home-fabbed (SWAG style) press brake and they wouldn't budge. But I was able to quickly whip up a die with more separation between the two sides and get the 3/4" thick w to bend with my 20t press. I upgraded my test arm to aluminum from cardboard to be doubly sure.
Trial 1 on the wider die was the right piece. Didn’t help. Trial 2 was adding the angle iron which increased the span almost double and I was finally able to get them to bend. I can’t do 90°, but I got them bent enough (with room to go further if I needed).
Final mockup and measurement/marking before tacking things in.
After confirming on the truck that things fit, I cut off the unnecessary stuff and welded the pieces together, reinsering the alignment bar for final weld.
And put some hefty tacks on the frame mounts and axle mounts:
Last steps are to remove one link at a time and flex the truck out to make sure there’s no unexpected interference with other components. I know for a fact that even flexed that the shocks will limit the travel before the arms hit the shock hoops, so I’m good there. The only thing I’m concerned with is if I leave the passenger side connected offroad (only remove the driver’s side link for simplicity) the link may interfere with the drag link under heavy droop. Time will tell, though. Locally I doubt I can get it to fully droop.
I'd also like to make the axle mounts tool-less quick disconnect - I've got some ideas on this. Oh, and tear everything apart for paint.
E-Locker or Bust!
Discussion Starter #1,474
Killer setup for the swaybar. I’m sure it will help out a ton on the road.
Thanks man! I just hope its not too stiff. Then again, my daily is a Mazdaspeed 3 that lifts a tire when I turn into my work parking lot ramp... so there's probably no such thing as too stiff :laughing:
sway bar setup is looking good so far. maybe go quick release on both sides at the axle side and weld another set of mounts to the shock hoops for when it's disconnected? pretty common setup on Jeeps
Well hot damn, that was my exact thought. It really comes down to if I need to remove both links offroad. If I remove just the driver's side, I need to tie the link up onto the arm somehow (should be easy).
If both need to be removed to accommodate full articulation, I'll tie them both into the frame or shock hoop like pictured there.
Something like this would be super cool, but overly complicated if I'm being honest with myself. https://www.quadratec.com/products/56016_300_07.htm
E-Locker or Bust!
Discussion Starter #1,476
It's 1.25" OD, but it's hollow. I never measured the ID, but I estimate it is around .2" wall thickness. I'll try and measure tonight.
The overall length is 36".
E-Locker or Bust!
Discussion Starter #1,477 (Edited)
Got it finished up and fully welded/painted last night after flexing it out to make sure things cleared. Also got one of the two quick disconnects prototyped, but I'll be redoing it with stainless so it doesn't rust.
First impressions are that the truck is WAY more stable on sweeping turns. I'm very happy with it and now wish I added this years ago.
Run BRP PN 0775778 in the wheel bearings. The triple guard will work ok but the other PN is a marine grade wheel bearing grease. You can run it in the bushings as well if you only want to have one grease on hand. We use both being a BRP dealer we have ample stock of each. Triple guard in steering components and bushings, The marine WB grease on trailers and anything that may see excessive pressure and heat. They both can be found for about the same price adn just about every marine manufacturer offers both types, different names and PNs of course.
E-Locker or Bust!
Discussion Starter #1,479
Sounds good. I'll likely make the switch when I do my next bearing service. This stuff isn't any more expensive than the Valvoline Synthetic EP I'm currently buying at the local parts store - I just need to plan ahead and stock some.
bobbing for fries
Same here. Been using marine grease in my junk for a long time without issue
The truck looks great, it has progressed nicely over the years. I can't always see the pics but still following along
