The Juggy I just bought has a master cylinder from a 2002 F350. I want to install a stock brake light switch on the peddle. My problem is that the rod that pushes the piston is too long. There isn't enough space to mount the switch. Also, I would like the peddle closer to the floor, so I need to shorten the rod connecting the peddle arm to the brake piston. How is the rod connected to the piston? Can I just pull it out, shorten it and push it back in or do I have to remove the master cylinder?
Thanks
Thanks
