1 - 3 of 3 Posts
I have just pulled a 22rte to put in my 85 4runner I have the turbo transmisson too. I Was going to send it to get rebuilt And bored And Forged piston So I could turn up the boost, then I found a 2003 v6 with 11 miles for 1150 bucks plus all the all the computer and Harness ects and he will even let be grind the motor mounts ot. Would I be able to get this to work. Would my turbo tranny mate up with it. There is little info that I have seen most Info that I have found on the bill board stops after 2002 and i cant find if the R150F even cme with the 2003 let alone how it compares to the R151f that I have. I know they ar eboth 23 spline. help!!!
Your R151 will work with the 5vz. You will need to use a V6 (3.0 or 3.4) R150 bell housing. This will bolt right up to the 5vz and the R151. You will also need the flywheel / clutch / TB, etc from either the 3.0 or the 3.4 Do not mix the 3.0 with the 3.4 stuff - use one or the other. IIRC the 3.0 has the clutch slave cylinder on the RH side while the 3.4 is on the left.
The R151 (gear drive Xfer) is a much better trans than the R150 (chain drive Xfer case).
This will make a nice swap.
1 - 3 of 3 Posts
