1 - 8 of 8 Posts
2005 Rubi for sale (price lowered)
71,205 miles $16,000 obo not interested in trades registered in Texas. located in phoenix but will be driving to houston towards the end of the month and can haul this down there if need be.
5.5 Rubicon Express LA
14" ORI struts up front/5.5 coils rear.
Blue torch fab crossover steering with rob bonney aluminum links
37" pitbull bias ply (85 % tread left) on 17" walkers
Warn rear tire carrier
jeeperman rocksliders
TnT phantom fenders
poison spyder rear corners
Arb bullbar ( corners cutoff for better approach onto rocks)
Warn 9.5ti
Rockhard add-on bolt in cage
Arb locker front/ yukon zip rear, arb mini air compressor
us alloy cromo's all around except for longside inner shaft on the front is ten factory (same ****)
hard top included ( one little scratch on it maybe an inch long)
full doors
jeep cover
spare axle shafts front and rear
extra races included for RE joints
The bad:
-if you want cold air i believe the low side line needs to be replaced it is leaking
-the rear RE trac bar joint needs to be rebuilt there is a driveline vibration over 60 mph due to this i believe i have the races for that one
- the hood is damaged from wheeling so you may need to put hood pins i've never had a problem with it though.
- the hinges that the doors slide into are bent just a hair (maybe a 1/16 of an inch?) where the doors wont go in i never worried about it because i didn't use the doors
1 - 8 of 8 Posts
