As many of you with the 2005+ Super Duties know, as soon as you add a suspension lift, you are running on borrowed time with the stock track bar. The 2011s have had some issues with a front end shimmy and the occasional spout of death wobble due to bushing failure.
I bought a Zone Offroad 4" suspension lift for my 2011 F-350 because I thought buying stock type tires wasn't enough of a challenge. But I digress. The kit came with a new track bar to keep the front axle pretty well centered, and to be honest it was pretty stout looking.
After a year and a half of driving it, I noticed a distinct clunk when cycling the suspension. I had GRMHick cycle the wheel for me and noticed the factory ball joint that was pressed into the axle had about 1/2 inch of plunge in it. The truck only has 25,000 miles on it. I knew I had to make this better.
I had done some searching for bars that eliminate the lower ball joint. I found some good track bar solutions for this, and some downright retarded ones
The Good:
Baja Customs Trac-Inator Ford SuperDuty F250/F350 Track Bar
Whoever designed this, clearly knows his shit. The price is good for what you get. The only issue I had with buying this is, I'm cheap and the custom machined uni-ball makes possible replacement in the future next to impossible. Also, there was a 7+ day lead time with it. I couldn't wait - I wanted to go wakeboarding and needed my truck back together
The Bad:
ReadyLIFT Ford Super Duty Anti Wobble Trac bar
This one (in addition to being wildly overpriced) creates a situation where there will be bump steer. If you look at the SD axle, the lower pivot point is the exact centerline of the balljoint. Moving that rotation point up with a simple bracket like RL's will cause bumpsteer. Someone clearly did zero engineering on this thing. An 8th grader with graph paper could figure this one out.
Parts list:
RuffStuff
Total cost $225
My first order of business is getting the old shitty ball joint out. I rented a ball joint tool, keep in mind that you will have to cut the shaft of the original BJ to even have a chance of getting the tool to fit over it.
Side by side comparison:
Next I tacked a guide plate to the top with a 1/4" hole in it to guide my hole saw to keep it centered in the bracket. I made sure to keep an even amount of material on all sides. The pictures are deceiving: the bracket is cast steel welded to the axle tube and it's over an inch thick. Drilling it out sucked.
Next after cleaning out the hole, I mocked in the uniball cup. Keep in mind that you still have to press the uniball in and out of this, but it means you can just order a new one if this guy ever wears out.
The Good:
The Bad:
Parts list:
RuffStuff
- 3 feet 2" x .250" wall DOM
- 1.25 heim
- 1.25 hex insert
- 3/4" misalignment spacers (more on those)
- 1 inch uni-ball with carrier
- 2 5/8 hole saw
- 1 can WD-40
Total cost $225
