2007 - 2011 Jeep JK Long Arm Lift Kits by Rough Country
Call 706-207-4140 Post Up, or PM to get your CCOR Discounted Price!
2007-2011 Jeep JK Wrangler 4"/6" Long Arm Upgrade
Kit Contents:
Front: Sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Rear: Stainless steel brake lines, X-Flex lower control arms and upper radius arms & hardware.
Applicable Models:
• 2007-2011 Jeep JK Wrangler (2 door)
• 2007-2011 Jeep JK Wrangler Unlimited (4 door)
Notes:
• Upgrades 4" or 6" kits only.
Benefits:
• Upgrades short arm kit to long arm.
• Dual Y-link suspension setup with longer travel arms.
• Prevents binding and rear-steer.
• Gain unparalelled axle flex while keeping pinion angles optimized.
• HD 1/4" thick skid plate protects transmission & transfer case.
• Lower X-Flex control arms feature:
• Massive flex joints with 2.5" diameter body and huge 1.25" threads
• OEM style Clevite rubber bushings
• All joints are fully rebuildable
• Fully greasable
• Adjustable retainer ring
• Lower joints pivot up to 35 degrees
• Made of 2" diameter heavy duty tubing
Specs:
• Part #: 790
• Install Time: 8 - 10 hours
2007-2011 Jeep JK Wrangler 4" Long Arm Suspension
Kit Contents:
Front: Lifted coil springs, adjustable track bar, sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Rear: Lifted coil springs, coil correction plates, track bar bracket, sway-bar links, stainless steel brake lines, X-Flex lower control arms and upper radius arms & hardware.
Shocks: (4) High Performance 2.2 series
Applicable Models:
Benefits:
• Increased ground clearance.
• Coil correction plates corrects the rear coil angle 10 degrees.
• Coil correction plates allows the rear coil springs to function more effeciently.
• Application valved Premium Performance 2.2 shocks
• Fully greasable
Specs:
• Part #: 786.22 - 2 door
• Part #: 787.22 - 4 door
2007-2011 Jeep JK Wrangler Unlimited 6" Long Arm Suspension
Kit Contents:
Front: Lifted coil springs, adjustable track bar, track bar bracket, pitman arm, sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Applicable Models:
Benefits:
• Fully greasable
Specs:
• Part #: 789.22
Rough Country's Jeep Wrangler JK Long Arm Suspension System/LIft - YouTube
