1 - 2 of 2 Posts
Kinda a dumb question, but I'm puting together a doubler, and need to know what to do abt filling the 203, how much, and where.
I'm guessing that I need to make a fill hole and drain hole, just don't know where and how much fluid to use.
Help would be appreciated.
What I've seen most people do is put a filler in the pto cover about halfway up.
On the two I've played with, I drilled/tapped a hole in the case... I'll have to double check how high I did it. But from what I recall, it was basically at the same level as the idler shaft.
1 - 2 of 2 Posts
