1 - 11 of 11 Posts
sorry, it is currently not for sale.
i just posted it so that others could at least see what they are looking for.
when i was searching i never saw one online.
i think i may try to draw the adapter(or get someone good at AutoCAD to) in case someone wants to make one. as i tear into it I will post more images if anyone cares.
damn that looks familiar <IMG SRC="smilies/biggrin.gif" border="0"> Got one sitting in my garage
were'not doin the 203-205 doubler here, are we?!
i'm working on a 400-203-205 setup right now and finally found a complete 400-203 setup with adapter.
anyone else have one of these for sale? need one more.
<IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0">
this is starting to turn into a 'i want a doubler' party.
i am thinking about homebrewing it. (actually farming out all the work)
anyone else?
hoping to do a shaft and adapter under the $740usd
heard one story of Moser shaft work costing $80
leaves $660 for adapter
i was thinking all one piece rather then 3 welded together
Originally posted by mj:
<STRONG>this is starting to turn into a 'i want a doubler' party.
anyone else?
</STRONG>
Have you read this article: http://www.bc4x4.com/tech/2000/gordtcases/gordtcases.cfm
might be useful if you plan a homebrew. Also a guy named Donovan on this BB was doing a unique home brew doubler if I recall. HTH
Does that 203 bolt directly to the 465, or is there an adapter between em? It looks direct to me, but I cant tell how you bolt it to the tranny (doesnt look like bolt will go thru it! Does it use a splined sleeve like the 205 or does the 465 output go directly in the 203? I've never seen one of those round here, all the ones I see are 205's bolted to 4-speeds..
Discussion Starter · #11 ·
i am guessing the adapter is what you can see in the pic.
looks like the 465 output slides into the input gear, but i havent pulled it apart yet to verify that. when i do i will tak and post some pics.
1 - 11 of 11 Posts
