1 - 1 of 1 Posts
I fixed the horrible gear/bearing noise coming from my 205. First I took the case apart and discovered the idler shaft had loose bearings.After the bearings were replaced the noise still persisted.The double U-joint rear drive shaft has a working angle of 14*,and that set up starts to vibrate at about 8*.I had a 1350 cv shaft made up and now the noise is gone.The old driveline never shook the truck but it sure tranfered alot of vibes into the transfer case. :beer:
1 - 1 of 1 Posts
