1 - 7 of 7 Posts
Im looking for a write p or some info on converting a chevy 208 to fixed yoke. ive searched and found that you could use a ford and maybe a doge but no real answers.
IM loking for more info on the doge setup.
208 SYE
We don't make a SYE for the NP208. The 241 is a better case and has quite a few design improvements than the 208. If your budget allows; the best bet is to pick up a GM 241 (assuming you have a GM application) and install the HD SYE onto it.
Thanks but i was looking at using parts from another brand 208.
Anyone on the weekday crew have an idea?
This is the differant case.:flipoff2: I took out 203 and had tis laying around and decided to try it with a 700r trans. Not really worried about hte slip yoke just heard it could be done and wanted to try it.
Yes it can be done cause I have one. It uses some Dodge parts, but since I bought and didn't build it cause I'm webwheeler, I can't give you the tech.
It started life with Chaz, you may PM him and find out who did it, other than that, there's a guy on CK5 that does the conversions, might want to post up there.
1 - 7 of 7 Posts
