1 - 17 of 17 Posts
• Factory built 20’ trailer
• White flat deck car hauler trailer
• 20' bed all steel deck trailer
• 7,000 lb capacity
• Brakes on rear axle
• Buddy bearing lubricators w/bra's on all spindles
• All LED lights
• Third brake, turn & stop light on back top of box
• All clearance lights are dual and work with turn & brake lights
• Steel hidden & locked loading ramps (never used)
• Steel modular wheels with trailer tires
• Teardrop fenders
• Matching spare & wheel with lock and cover
• Removable coiled & lighted trailer wiring plug
• Enclosed storage box 44" long x 84" wide x 60" tall
• Radius front top edge
• All aluminum skin, framed with 1" x 1" square tubing
• Aluminum trim all around on outside
• Full width doors on both sides with open door hooks
• Doors 3/4" x 3/4" square tubing, insulated, aluminum skinned, S.S. polished trim
• S.S. polished locking paddle door latches
• Insulated, lined & trimmed with white vinyl bath panels
• Overhead 12v lighting
• Passenger door Pit Pal wall storage unit with fold down work tray
• Hooks for cords, air hoses etc. storage
• Aluminum wall mounted storage boxes for Latex gloves, paper towels, Kleenex
• Wall mounted dual row tie-down hanger rods
• Mid level upper removable rack for generator and compressor, so floor is clear for storage
• 3500 watt continuous, 4000 watt surge generator (less than 2 hrs. run time)
• Electric start w/battery on generator
• Center upper rack for generator and compressor (compressor not included)
• 120v external plug with interior wiring and plugs
• Winch mounted inside with controls (2000 lb)
• Sealed large 12v battery & box
• 12v charging from generator and 120v charging (charges both batteries)
• Battery maintainer\charger
• 2 each 12v remote controlled loading lights facing back for loading
• All wiring concealed behind panels
• Ribbed rubber floor mat
• 4 each frame mounted D-ring tie downs
• Front aluminum diamond plate stone guard
• Plastic protectant tape on leading edges of trailer and fenders to protect from rock chips
• 3M Reflective tape around trailer & box
Trailer has only been used 4 times (less than 1500 miles) is one owner and less than 2 years old and is always stored inside. $3900
I need an enclosed trailer and this is the only reason for selling it.
E-mail for more pic’s of this trailer [email protected].
Is the deck length (20ft) including the box, or is it 20ft behind the box? How wide is the deck? How hard is it to remove the box?
1 - 17 of 17 Posts
