most likely someone is going to tell me to use the search browser, tell me go back to stock or convert to propane. This is my last resort
i just bought a new weber from lc for my 20r and it wont start I have everything plugged except for the vacuum advance that runs to the carb. I did manage to get it to start once but it wouldn't idle and i had to keep giving it gas to keep it running. while it was running it was extremely rich (looked like a diesel rolling some coal)
i have the carb set at baseline settings (1 1/2 turns out on idle and speed screw) i have tried the regulator set at 2,3, and 4 psi with no luck to get it to run. I've also tried choke on and off with only 2 starts but no clean idle.
do i just keep trying to lean it out or do i try to re-jet it? could my vacuum advance be bad? or could i have a vacuum leak somewhere? is there any information i'm missing?
