1 - 8 of 8 Posts
I am new to TOYOTA's......I looked through about 15 pages on the 22-re before I started gettin a headache soooooo my question is : what is the latest model car....truck.....van.....plane......I can get a 22-re out off to replace the one in my 1986 4 runner ? (what year ,what model)
Thanks :D
mines a 94 in the truck, could get up to model year 95 in pickups. Dont know what else is out there though. They still using them in forklifts??
'95 is the last year. It is what I put in my '86. Since mine was carburated, I also used the EFI, which in '95 was OBD II emissions, using a catalyst moniter and some other extra sensors.
For our purposes 95 was it. 85-95 should work, they didnt change a whole lot. Toyota still produces them in limited numbers outside of the U.S., presumably for applications like fork-lifts that JW mentioned.
Who gives a damn about the year of the motor. I would be more concerned with the mileage on it. You can get an 89 22RE with 80,000 miles and a 95 22RE with 150,000. Check mileage but if you must know, 95 is the last year of the 22RE.
Hey tuck , where is that 89 motor located :flipoff2: but really if ya need an explanation I will assume your more than a lil slow so here goes......if I see a 99 model or a 96 model or wtf ever else I see I now know what year trucks to look for.....get it:confused:
I'm slow? I'm slow because the only fawking difference between a newer and an older 22RE is nothing more than a few nuts and bolts? A 95 22RE and an 87 22RE are virtually identical. What makes you think because the motor is a little newer than you can make the assumption that it is more mechanically sound? Whatever, just trying to help you, but I guess that an insult is justifiable for offering help.
Yes tuck you have been very helpful .I had no idea that a lower milage engine in a older truck may be better than a high milage engine in a newer truck :confused: no chit
I will try again to explain my question to you....."I am new to TOYOTA's" I am pretty sure about when the 22R-e came out ...86 ? maybe 85.....but what I had no idea of was if they still used them or when they quit . now I know.
The year that they quit using them.....that was my question .I got the answer.
I think you are trying to hard to read between the lines.
My goal was to know what year models to look for since I believe I know when they started using it I needed to know when they quit .
I hope that is ok ? I promise if I find a 22R-e in great shape I will not care what year truck it is in.....hows that ?
do you really think I should look for 1 that is mechanicaly sound
:confused: :flipoff2:
1 - 8 of 8 Posts
