1 - 15 of 15 Posts
Scraped all the emissions chit and just wanting to have only the bare bones for wiring on the truck
If you have done this and got a diagram put togeather that would be great but if not any help would be nice... And yes I got a autozone bible!
Thanks
Let's work backwards, what do YOU want to stay on the truck?
Look at it, look at the diagram, get it working with what you want removed, then go back and remove all unused wires from harness.
Thanks
I have...... and you should can that bible...
Factory year specific wire service manual is what you need. My 86 is a 12 page print out.
Easy peasy....
Discussion Starter #8
Well my version of bare bones wiring works great!
Started up without any issues.
Disconnected all connectors and re ran thru firewall , secured everything and reconnected main power and fried 40a block fuse... Are these fuses easy to come by??
Discussion Starter #9
I'm about to the point of just installing a " simple push button start"
Iv had no luck finding a fsm doc online that is exactly what I needed.
All I need to know is
What wires @ the distribuitor need to be hot and relayed back to the ignition
Along with the starter and alternator
I know someone has done this
All help is appreciated
If you're ditching EVERYTHINg and don't have to worry about emissions, you should switch to GM ignition stuff. If you do that, all you need is your standard ignition wires in the cab, with a hot wire running to the ign module/ coil area.
You can run a 22R/ GM ign setup with only 5 wires running to the cab- 2 wires to the starter, 2 wires to a late GM alternator (or 1), and one wire to the ign module.
Thats all for today honey, now clean your bib from the spoon feeding and get back to work! :flipoff2:
Didn't you get it going the other day?
link to what? GM ign stuff is in FAQ. The rest is self explanatory...
5 wires. three this way< and two this way^:grinpimp:
The answers you seek are in the bible.
I will spoon feed but just once.
http://www.pirate4x4.com/forum/toyo...53-complete-bypass-toy-ignitor-coil-30-a.html
data:image/jpeg;base64,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
1 - 15 of 15 Posts
