1 - 3 of 3 Posts
Hello,
Can someone tell me if there should be a paper gasket between the carb and intake manifold on top of the 1/4 inch thick rubbery gasket?
Thanks in advance,
Kurt
If I remember correctly, no. The phenolic block already has the gaskets glued to it. Normally you would replace the phenolic block with a new one whenever you remove the carb. It has been a few years since I had to look at a 22R carb so this may be wrong.
Suprisingly Toyota dealership was of help. According to them you are correct the gaskets are attached to the insulator. Cost is $35. They are the only ones that have it.
thanks for you reply.
1 - 3 of 3 Posts
