1 - 14 of 14 Posts
looking for a straight answer here fellas.
are all the 22r/e blocks interchangable? from what i could gather the head were the only things that differed over the years. thanks
so in summary i can use any 22r/e block as long as i account for port matching and a timing chain issues?
so all the internals off an 84 will work in a new or old block?
Iam pretty sure the pistons are different on an 84 (raised top) and will only work with an 84 or earlier head. 85 and up had flat top pistons.
Contact Ted at engnbldr.com. He will break it all down for ya.
"RE:The difference is miniscule, but you will notice it in compression testing. I actually recommend getting the newer block so to lower compression and gain gas mileage."
Lower compression = less power. How does that mean better mileage? Even a slightly milled 22r will run on 87 octane...
The 85+ block is taller.. Everything will still bolt up, but you'll need a double row timing chain on the bottom. I don't know how much this will change compression.. Again, ask Ted...
1 - 14 of 14 Posts
