It's Done
Follow up with what I did in case anyone else searches for this.
The dowel and new bolt from Toyota were under $5. It is a bitch drilling a hole in the old pin...it seems hardened. A right angle drill helps a lot. Just took the radiator shroad out and drilled through one of the holes in the sprocket. Broke a couple of bits but finally got the hole deep enough. I'm always scared of breaking those small ez outs, since the pin is not threaded I just used a sheet metal screw, put some plyers on it and tapped the plyers with a hammer to ease the pin out. Almost dropped the new pin down into the oil pan while trying to get it in. Lucky I had stuffed a rag down there (I also ordered 2 pins, just in case) Had to break out a counter sink to clean up the edges of the hole a little b4 the pin would go in.
The bright link was no where near the TDC cam mark...it must have jumped 6 or 7 teeth when the pin broke. Since the crank hadn't been out I just lined it up on TDC and lined the cam up the same, then put the chain on. Used a long socket extension through one of the sprocket holes with the other end on top of the rocker housing and leveraged it up to push the tensioner in enough to get the chain back on the dowel. It didn't want to go in so I rocked the crank back and forth a little and it slid right on.
Set the timing by eye, buttoned it back up and it fired on the first crank. Put the timing light on ... 5* BTDC on the nose.
I think it would have taken less time to just replace the cam, but this was cheaper. I didn't have anything else to do this weekend anyways!
