What did you do with the air valve, if anything? Last I checked, that is a needed part. Especially, here in the midwest.
Air valve function: Coolant from the engine passes through, heating a diaphram. The diaphram changes the flow of air through the opposite site of the valve, into the throttle body, lowering the idle speed. This was used in place of a solenoid on the throttle body, to adjust the amount of air intake at idle speeds. Primary function, to adjust idle according to vehicle temperature, and time for warm up.
