41 - 44 of 44 Posts
adjust your air flow meter a couple clicks loose to add more fuel
EGR Exhaust Gas Recirculation puts exhaust gas during part throttle which takes up the space of fresh air in the combustion chamber .... because there is less air less fuel is needed to maintain 14.7:1 AF ratio so often when you remove an EGR the vehicle will seem hesitant during part throttle like drivability gets worse because its running a little leaner then it did with a functioning EGR
on some old fuel systems I used to tune, which did not have any RAM ... learnability and used a hot wire air flow sensor which couldent be adjusted so I edited the file (tuned the ECU) around the removal of the EGR
really the EGR is a fuel saving device which dosent operate at full throttle usually so it dosent cost power... it cools the combustion chambers and reduces NOX emissions
anyway a little tech on EGR which is probably totally useless here but if anyone was cuurious
have a great weekend
JAK
Sorry to dig up an old thread ....
This pertains to what I am currently trying to do .
I have a throttle body that I have removed all the emissions tubes from currently.
How did you go about welding up the holes ?
Also has anyone had any experience with eliminating the IAC valve from the bottom on the throttle body ?
Thanks
Thanks
I have pulled the tubes from T-bodies and threaded the holes for plugs or set screws numerous times.
41 - 44 of 44 Posts
