1 - 6 of 6 Posts
I just got my purdy little 87 4runner this evening (had it shipped from Denver, it was an Ebay thing ;) ). It's a 22r/e-5 speed. The guy I bought it from said he believed it had a bad head gasket due to HC's in the coolant. It ran ok, but I tore the head off tonight anyways since I had planned it from the start. I'm not new to engines, but I am new to this 'furin' stuff. :D
I did a comp check and all cyl ran about 150 (on my crappy guage) except #3 that read around 130. I'm guessing this was the leaky one. I couldn't really see any 'smoking gun' on the head gasket issue, but I did notice a slightly different coloration from the #3, to the bolt hole and water jacket. I THINK that might be where it was. Any suggestions on stuff to look for that is Toy specific when it comes to this sort of thing? I'm already doing the timing chain since it's apart, any other suggestions?
One thing did strike me as strange. I noticed that the #1 and #3 cylinders looked like the exhaust valves were wet while #2 and #4 were dry. Any idea what might cause this?
EDIT: One more thing, it won't seem to go into 1st gear fully. Is that a common issue?
BTW, what brainiac decided runnning a wiring loom under the plenum, and through the middle of the lower intake manifold was a good idea? :shaking: What a PITA that is making everything. I pulled a couple of 22r heads off in the last week or 2 for a friend, and damn that was a lot easier! :laughing:
as far as the ytranny not going fully into 1st gear , there is a plastic cup at the end of the shifter , it could be broken or missing , as well as the plastic ring
Bushing, Shift Lever 33548-31010 $3.74
Seat, Shift Lever 33505-35020 $8.89
CRAZY MATT said:
Valve seals could be dried up and the exhaust guides could be toasted
I was kind of thinking that. I just found it odd that it was only on #1 and 3. 2 and 4 look perfect. A
Good deal, and thanks for the info!
Thanks to you also Paz for increasing my knowledge of factory Toy parts. It seems like every time I talk to you, I leave feeling enlightened. You need to quit being helpfull, or risk ruining your hard earned reputation.
:flipoff2:
1 - 6 of 6 Posts
