1 - 20 of 23 Posts
motor runs great at about 25* advance. wont retard any lower than 10* and runs like crap at that setting. jumping the "T" terminal doenst do a thing. i pulled the head a month ago and marked everything, and it all went together fine. get this. at 0* TDc ( exhasut stroke) and cam is straight up and the rotor is DIRECTLY on the #1 terminal...runs smooth, occassional sputtering, way better than it was....i would think that it would run REALLY bad if i was off a tooth, and the fact that the "T" terminal doenst affect it anymore makes me think its electrical. or is it the chain? only 20 k miles, did i get it messed up when i took the head off? pushes 37's to 90mph on the freeway, so its not short on power, just around town it sometimes does and sometimes doesnt have any power.......HELP i'm gona take it aprart tonite when i get home.....thanks <IMG SRC="smilies/usa.gif" border="0">
Dallas,
This STILL points back to the TPS. Whether it is new or not, is it correctly adjusted? The timing cannot be set right if the TPS isn't adjusted to where it should be.
Double check the TPS and try to time it again. Everything else related is mechanical, and all of that sounds like it is setup right <IMG SRC="smilies/bounce2.gif" border="0">
A off and on bad airflow sensor was making my 86 do that I took air intake cleaner and spray it down real good washed all the crap out of it moved the flap around a bit.i also cleand the intake.this was momentary thing that could last 1 min to 1 hour but would go away when i hit the top of the air box with my hand.
no, it was not this way b4 i pulled the head...toytech, does a misadjusted TPS cause my "T" terminal to do nothing when i jump it to set the timing? i can still get codes okay. thanks guys, i'm gonna pull the valve cover and try to check the chain again, maybe drop the pan and see what i get. if i cant fix it , someones gonna get a hell of a deal on this trruck! i'll pay someone $50 and buy lunch if you are knowledgeable about 22re's and come to my shop to help me <IMG SRC="smilies/smile.gif" border="0">
25 degrees of advance without the terminal shorted is probably about half that, so I'd bet your around 12 degrees right now. Mabey somone could confirm this.
Are you using a timing gun with an advance knob on it?
[ 09-18-2001: Message edited by: wes ]
Originally posted by Michael Alexander Britts...American:
<STRONG>im having the same prob. how do i go about adjusting the tps??? thanks</STRONG>
Its on my page. You need to have a good IDLe signal to tell the computer you are at idle for setting the timing:
TPS Info
Could also be the distrubutor is off a tooth, too. I marked mine before I removed it so I was able to put it back pretty close to the correct time when I rebuilt my engine.
I had this happen last year when i redid my timing chain.......It was the distributor off a tooth. i would say second choice would be the timing chain off a tooth.
You can check the top cam marks by just lifting the front of the valve cover.
If the chain is off by a tooth, pull the bolt holding the cam gear on, and while keeping tension on the chain (to keep it on the crank gear), slide the cam gear forward off the cam just enough so you can rotate it inside the loop of chain and line up the shiny link with the dot on the gear, then reinstall the gear. JUST MAKE SURE THE CHAIN DOESNT SLIP OFF THE CRANK GEAR.
Discussion Starter · #12 ·
maybe when i pulled the head last month the chain slipped off the crank? i set it on the guides while i pulled the head........this is what i thought was up, BUT i checked it all out and it looks good, so i'm gonna check one more time. when its at TDC the rotor is DEAD ON the #1 terminal on the dist. cap.......jumping the "T" terminal does nothing.......WTF?
[ 09-19-2001: Message edited by: Fightin' mad fireboy ]
Discussion Starter · #13 ·
i just got back from the shop and EVERYTHING is good to go...timing chain and distributor are BOTH exactly where they need to be.......jumping the "T" terminal still does nothing, BUT i can pull codes and i got a code 11. this is....??? i'm still stuck with the timing at 25* and no "T" terminal working right, a local guy said maybe the harmonic balancer slipped? i have never heard of this b4
Fightin' mad fireboy---90 mph with 37" ties. Wow. Why are you messing with it more? My 92 has the cam timing in factory spec with ignition timing and I can't do hardly 75.
Discussion Starter · #17 ·
hehehe...it does scream, BUT sumthing is wrong if its showing the timing like that and the "T" terminal doenst affect the timing......and it has bouts of slugishness. so thats y i'm messin with it.....BTW i do have a cam, header, and freeflow exhaust
Discussion Starter · #18 ·
UPDATE: i just pulled the codes and i get a code 11......AC vaccuum switch has the wires cut, BUT i plugged the lines AND my AC isnt hooked up. what else is up? TPS circuit? HOW do i check that?
Originally posted by Fightin' mad fireboy:
<STRONG>UPDATE: i just pulled the codes and i get a code 11......AC vaccuum switch has the wires cut, BUT i plugged the lines AND my AC isnt hooked up. what else is up? TPS circuit? HOW do i check that?</STRONG>
TPS info is in my last post, but here it is again.
where is the diagnostic termanal on a toyota? i have looked all over the truck and where the manuel says it supposed to be but i cant find it. can some one please tell me where to find this sucker? BTW its for a 1985 toyota 4 runner. Thanks.
1 - 20 of 23 Posts
