22 re runs great, as long as I jump 12 volts to the coil. Once truck fires and runs for a min, I can remove the jumper and it runs fine. Bad relay? Bad something? Fresh plug wires, fresher alternator (works) and fresher coil. Runs with either coil as long as 12 volts is put to it on startup. Also, the charge light in the dash. Comes on in the dash when I jump the coil. Not when the key is turned on. Not sure what that means but it must be something. Help!
