I just finished putting an 85 efi moter into an 86 efi 4runner today, I finished up everything and went to start it and all it does is when you turn the key to were it should start cranking it just cuts all power and nothing happens. My dad said sometimes there will be a presure valve to let out air from the injectors when an engine has sat along time....Is there one of these? Also isn't the fuel pump supposed to shut off once it has built up pressure? It just keeps going and doesn't shut off......Should it keep going or should it turn off?
Thanks, James
Thanks, James
