1 - 6 of 6 Posts
· Fabster
Just got a turbo truck. Is there any cheap ways to pump up the output?
get on that mailing list i was telling you about.. alot of knowlegeable guys there Just on turbo stuff .. I can tell you this.. turbo REALLY respond to stuff like a open exaust and free flowing intake.. way more so then just a normally asperated motor.... any more then that and it starts getting pricey.. The best mod you can do is that turbo from TEC but you are looking at about 1300.00.. there are alot of guys building there own manifolds and getting junk yard turbos doing about the same thing...
Heehee, don't waste any time, do ya? :D
Crank the boost, get an intake, and get some sort of fuel psi regulator to make sure you don't run too lean. The Dynomax exhaust I threw on there isn't too old, but a larger diameter pipe would work well if you do crank the boost.
1 - 6 of 6 Posts
