1 - 3 of 3 Posts
Okay, I am a big idiot... took the transfer case off (cracked case) and put a new one on but cannot remember which way the tab/lever mounts onto the case.. Is it up or down? This is a 1993 YJ with the 231.. Better yet, when looking at the shift shaft, which way is 2hi and which way is 4low on the transfer case itself (not on the shifter up above)
I'll walk outside and look, but my memory says tab points toward sky and far rearward is 4lo...... at least on the 231 in my 1998 TJ IIRC.
**EDIT** I am dressed for work, but it appears that I am 100% correct.
1 - 3 of 3 Posts
