1 - 11 of 11 Posts
Hey guys, I bought rig recently with 15" 24 hole DIY inner rings. The tires are mounted on the inside like a normal tire without outer rings. After some research I believe they're KORE (doesn't exist anymore?) but not sure, anyone know a vendor for some outer rings?
Discussion Starter #2
Just realized I haven't posted in almost 5 years...holy fawk. :laughing:
Measure the bolt diameter and bolt spacing and have someone burn some new rings. I'm sure you have a local water or lazer cutter.
Looks like those were meant to be wheel stiffeners not bead locks. The face doesn't look flat enough to make them be beadlocks.
Discussion Starter #9
Installing DIY beadlocks consists of welding then grinding a smooth finish to prepare the surface for the tire, apparently whatever previous owner did this missed that memo.
Discussion Starter #10
I agree, look like rim stiffeners to me. Iv never seen a beadlock kit with a decorative interior plate.
Looks like I'll have the first set, I don't see the point of scrapping the wheels just because the inside plate is larger than the outside. I'll have to weld/grind smooth the wheels and have some outer plates cut. If they are just rim stiffeners, I don't see the point of the bolt holes.
1 - 11 of 11 Posts
