1 - 8 of 8 Posts
$28,000 Custom Buggy / PJ Trailer $5,000 / OR BOTH FOR $30,000/or best offer
Contact Darren 702-839-0570. Las Vegas, Nevada 89129
5.3, head work, headers, RV Cam, all new sensors, new plugs, new plug wires, new coil packs, new injectors, later model fuel rail to fit Corvette-style filter/regulator, later model bracket for TC pump, new water pump, new 180-amp DC power engineering alternator. Engine runs excellent. Plus it was rebuilt and has 1000 miles or less.
Turbo 400 transmission with cooler and fan. Trans 1000 or less miles.
Atlas 4-speed T-case. T-case 1000 or less miles.
Engine, trans, T-case has less than 1,000 miles.
11.5 wheel base, 48.5 inside width, 37.5 seat to roof, 19.5 inch belly height at 8 lbs of air, 23 inch at 32 lbs of air.
Rear drive shaft is 1/4 thick.
CBR radiator, Optima battery, new Superwinch Talon 18-SR with 18,000 line pull.
Trail gear ram, PSC pump, cooler with fan for steering, steering also has a filter.
12 gallon custom aluminum tank with baffling. Tank easily last a full day.
Sturdy and thick aluminum oil pan with baffling.
350 Ford dana 60 front, ARB locker, king pin style, knuckles are reinforced with 3/16th plate, chromoly inner and outer shafts, Yukon super joints, Yukon chromoly locking hubs, new seals, new American bearings, new slim chromaly ring, and 513 gears.
14-bolt rear, disc brakes, back-bone truss, shaved kit, new seals, new American bearings, 1410 replaced 1350 U-joint, new ring and pinion, 513 gears, spool.
CNC brakes, fittings are AN.
4-link suspension all around, 1.5 upper, 1.75 lowers, aluminum links, chromoly heims.
43-inch TSL tires on 17-inch KMC beadlocks. Plenty of tread life. The tires were groved.
14-inch ORI shocks on all four corners.
This buggy was completed a few years ago. It may have between 10-12 trail runs only. It is very dependable and reliacable. I hate to get rid of it but I am moving. All parts are new condition. No old parts.....It has been in the garage since birth. I am sure there are things that i am forgetting.I can send more pics at request or answer more questions. I am located in Las Vegas, Nevada.
No title.
Like New TRAILER (additional): 2015 PJ steel deck Buggy Trailer, Drive over fenders, Bulldog receiver, Gross weight 9,899, Extra anchors, used to trailer buggy, has original tires, LED lighting. Side loading ramps, leveling jacks. Trailer is 16’ long and 83.5’ wide inside fender to inside fender.
3108327
3108328
3108329
3108330
3108331
3108332
3108333
3108334
3108335
3108336
3108337
3108338
3108339
3108340
3108341
3108342
Discussion Starter #7
Wrong forum. Mooving
Hey there, we added pictures and edited the description to include some things people have been asking about. The post still says "pending." Any idea when this might be approved and posted? Has it been done correctly? Thanks!
1 - 8 of 8 Posts
