1 - 20 of 26 Posts
Guys,
In a C series IH truck, besides cosmetics, what is diffrent between the two ratings? I know 3/4 tons have better axles, and a diffrent wheel pattern, but is that it? are the springs diffrent?
I'm wondering if I found a killer deal on a half ton, what would it take to convert it to 3/4 ton?
NQS
well I'm asuming its a 1968 1200-C series?? or a 66 C-1200?
front has a HD dana 44 up front (lage ball and external locking hubs) is its a 1/2 ton (1100) it has a small ball dana 44 with internal hubs
rear is a dana 60 or an IH corperet in the 3/4 ton and the 1/2 has a dana 44
both use an divorced NP 202 transfercase engins could be anything from a small inline 6 (most un likly) or a V8
3/4 ton has heaver duty springs then the 1/2 ton
the 1/2 has a 5 on 5.5 bolt pattern and the 3/4 has tis very rear large 6 lug bolt pattern with split rims
if you want to make a killer 3/4 ton IH just kiss, swap in chevy 3/4 (or 1 ton) axels no point in fwaking around with them odd ball axels
any thing else you want to know
No specific trucks in mind. I really like to look of the c series travelette, but right now I'm too broke to go looking for any in particular.
I may know of a '68 1100 i can get reasonably, but i need something I can tow with
Thats what I was thinking of doing.
NQS
well you can save the hassel and buy this rust bucket for cheap and it has the axel converion done allready
Th price is right, but I'm interested in either a travelette or travelall
Was yust chatting with ryan, said he'd deliver one here for gas money. but from his location still pretty expensive.
When I get serious, I'll most likely start looking down in arizona for a rust free one
NQS
Joe,
Depends on what "3/4T" features you want.
I only have info for '71, but in '71 the 1/2Ts had a lighter frame than the 3/4 and 1Ts (they shared the same general frame, except for the LWB Travelette that got an even beefier frame)
So the 1/2T frame will be lighter.
You'll want to change to the 3/4T or better leaf springs (and/or air-bags) to go with the higher GVW axles and tires.
For towing most trailers, the frame strength probably won't be an issue. The 1/2T frame is fine for attaching a receiver hitch and pulling 6-8k-lbs.
For that matter, if the 1/2T is in *good* shape, you could probably pull with it as-is for a while.
I used my 1110 Travelall to pull with for about 6 months. Less than idea, but it worked alright once I learned how to load the tongue weight and how to drive it correctly.
Definitely prefer the excessive GVWR of the Travelette though.. doesn't care how the tongue weight is..
I think the different frames will become an issue only when you start pushing the limits. 10k-lbs trailer maybe.. or loading a full ton or more of "stuff" in the box.
Otherwise.. buy the 1/2T, change out the springs and get some axles from a 73-91 Chevy 3/4 or 1T pickup or Suburban and call it a day.
Re: Re: Re: I like it
hell at that price ide buy it too an just slap on my 68 title
its just 4 screws
edit
Bwahahahaha "dayna" axels bwahahah
You Canadians get away with using screws?
Anything other than pop-rivets draws suspicion around here..
its just 4 screws
edit
And if you don't just happen to have a '68 title and VIN plate laying around......:rolleyes:
Re: Re: Re: Re: I like it
Washington, file for lost title, produce a signed bill of sale from previous owner, file it all, pay your fee, a couple other little things, and be done. You won't get full title for a couple years or something, but it is legal, legal to own, and legal to drive.
Still have to pass some inspections to bring it into the state, but a little elbow grease....
Figure one of these days I will convert my Pickup to 4wd. Need that 4wd for some of the places I take the Boy Scouts camping...
(caugh) Read sig (caugh) :rolleyes: :rolleyes: :rolleyes: :rolleyes:
and yup factory philups screws on the vin plate
they never check for that crap around hear
Re: Re: Re: Re: Re: I like it
What about the fact that the VIN plate was also removed and placed on another vehicle. If you applied for a lost title, then there would be two vehicles sporting the same VIN. Does that shit fly in Washington?
Discussion Starter · #18 ·
I'd like to be able tow a single vehicle trailer and use a slide in camper. I may to cut down on weight & cost get a truck bed tent, but I want a kitchen, so that means camper
NQS
And your one to make fun of someone's spelling mistakes....:rolleyes: :rolleyes:
1 - 20 of 26 Posts
