Can we puhleeze get through one friggin' 3-link post without bashing SG!?quality piece of work and it looks like ya can get the diff out without stripping the whole front axle out unlike my safari gard piece of shit.
Ian
If you need a tester in this hemisphere, I'm here, Ooh! Ooh! Pick me, pick me, I'll try to break it:flipoff2:Thats looks sweet mate!
I think you should send me a full kit so I can do some testing![]()
If you don't mind, can you tell us what your separation is between the bolts on the upper links and the bolt on the lower central link on your axle end (vertical). I think that is what he was trying to ask. ThanksI have about 8/10 cm of vertical separation between weld brackets on axle and engine floor (TD5) at full compression. Under the trackrod-hole I have welded another bracket (6mm thick) to get it more strong. I also re-designed another version of it with an 8 mm bracket under the trackrod-hole for the others I will build.
I try to find the right compromise between resistance and ground clearance...
