1 - 15 of 15 Posts
I was going to search but since its broken. How do you install the axleshaft into the birfield? There is a snapring on the axleshaft and I feel a grove where a snapring could go in the birfield but it doesnt seem like the snapring will do anything. Any help would be appreciated. I was going to search for the answer but its broken.
Just push the axle into the birf until the snap ring snaps into its groove. Be sure not to fold over the snap ring by forcing it into the birf.
Wicked Raciest !
You will think different when you try and remove the birf from the axle, if you do not know how to do it, it can be a real bitch!!!!!:flipoff2:
and make sure that you don't go past the groove with the snap ring and the end of the shaft actually ends up in the bell. This will cause damage if run like that
I believe the long's are made so this doesn't matter.
All of the 30splines I've seen have Martacks on them to prevent poeple from driving them into the birf to far. I know Mine and Kajo's have them for sure. I do remember it being a problem when they first came out though.
On the newest 30 spline longs the axle can't go in to far due to the splines being cut at the correct length so they bottom out when the snap ring is seated in its groove.
Thanks Manson
Yes the newer shafts have been that way for a while now. :)
Skii4x$ said:
the snap ring really doesnt seem like it does anything but oh well i listen to people that have done it before
Yes the snap ring is NEEDED like they said it keeps the inner shaft from going out of the birf into the locker. If did go out of the birf part way you would only have about hafe the spline contact in the birf.:)
And we do have a teck line.
1 - 15 of 15 Posts
