Where can I find 31 spline axles for a 74 bronco at a good price!!!??
That price is just the shaft, by the time you add bearings and studs (don't forget to have the axel retaining bolt hole put in) they are $427 to the door in WA for the last 2 sets I bought. They also make a 33 splined spool for the 9" if you are going woth a spool then you may want to consider that because the axles are the same price up to 35 or 40 splined.JJ said:moser axles are $295 for a pair of hardened axles. pretty good price. check out moser online.
