1 - 6 of 6 Posts
I have a stock 2001 S-10 Zr2, and a freind of mine is going to give me his old tires (32/11/15). what i am worndering is am i going to have to crank my torson bar all the way out to fit the tires. the stock size are 31/10.5/15. any help would be great the last forum i was in no one could tell me anything but how to lower a truck.
you probably won't have to do anything except mount them up and run them. The biggest factor on those trucks is the backspacing of the wheels. Aslong as you keep your stockers you'll be fine. If you do run into some problems it'll be upfront and more than likely just some minor rubbing on the front bumper/airdam and/or the rear portion of the fender. You can remedy this by either trimming the offending parts or cranking your t-bars. I'd run them and then decide.
depends on the width of the rim. 8" rim and you are fine.
1 - 6 of 6 Posts
