1 - 5 of 5 Posts
I have one (Scout D300 & JB 32-spline front output) but I haven't gotten around to installing it yet. All you need to do is increase the bearing bore in the front output housing to accept the bigger bearing. That part of the case is no different than the Jeep case, so the same shaft fits both versions. Both versions require the front housing mod.
Discussion Starter #3
Thanks for the info Mechanos. That was exactly what I was trying to determine. I thought that was the only modification needed, but I have been unable to confirm (even JB did not know the answer).
now why the hell would you sell a product for a particular thing, and not know if its gonna work for that or not??:shaking: did the same thing to my np 205, it had a male 10 spline input i installed a female 32 spline, only had to machine the bearing hole bigger
1 - 5 of 5 Posts
