1 - 5 of 5 Posts
i have a brand new take out set of newer design side gears not the 60's-70's style for a spicer/dana powerlock posi unit. these are BRAND NEW never run.
i converted the unit to 32 spline for rear aplication so dont need these now.
lookin to get $75 bucks shipped for them to you in usps flat rate box.
please send me a pm for sale info so i can make the deal with you thanks.
location of these parts is 14845 ny up state.
I didn't know there was two styles of power lock.What year did they change?I may be interested if these will work in my power-lock. You're not thinking of the trac-lock are you?
def NOT trashlock unit thats weak for a so called posi .
you can update the older with new guts no problem from what i have been told and read if you have a good old case to use.
fresh out of a power lock thats going in a axle i am redoing that had a weak / worn traclock in it before.
from what i have found the early units had a 2 peice side gear setup and then this droped on the clutch surface disk. got to pull unit apart to see what ya got. easy to tell.
and this is a newer power lock as it has the abs tone ring notch in it and date code shows few years old.
no problem with you asking now you know what i know on them.
pm me your email and i can send you a pic of the gears .
Guaranteed mine is old enough that they weren't thinking bout tone rings. It's a 16 spline out of older ford truck I believe. I'm with you on the trash lock lol! i'll send you that pm.
Discussion Starter #5
bump to the top still got them ready to ship out in flat rate box.
1 - 5 of 5 Posts
