1 - 8 of 8 Posts
Banned
Since I am new to the board, but not new to Jeeps I figured I would let you guys/girls know what I am working on. I currently have three Jeeps, a '00 XJ, '73 CJ-5, and an '85 CJ-7. I recently picked up the 7 for $650. I will be getting a 350 with TH350 for $400 to throw in it. Does that sound like a good combo combined with the Dana 300? Any things I should take into consideration? Does anyone have this combo and if so, do you have a page I can look at?
Originally posted by XtremeGod:
<STRONG>Since I am new to the board, but not new to Jeeps I figured I would let you guys/girls know what I am working on. I currently have three Jeeps, a '00 XJ, '73 CJ-5, and an '85 CJ-7. I recently picked up the 7 for $650. I will be getting a 350 with TH350 for $400 to throw in it. Does that sound like a good combo combined with the Dana 300? Any things I should take into consideration? Does anyone have this combo and if so, do you have a page I can look at?</STRONG>
Since I'm a cheap bastard I avoid adapters whenever I can. I suggest a 205 transfer case. I'm running a 350 tpi/th350/205 in a cj7 stretched over a J10 frame. <IMG SRC="smilies/skull.gif" border="0">
<STRONG>Yeah, but then I would still have to find and buy that case.</STRONG>
205's are easy to find. Don't pay over $200.00. Still cheaper than Advance Adapters and you could sell the 300 to recoup your cost and will probably make a profit!
Banned
Originally posted by hewl35:
<STRONG>205's are easy to find. Don't pay over $200.00. Still cheaper than Advance Adapters and you could sell the 300 to recoup your cost and will probably make a profit!</STRONG>
But Novak is even cheaper than AA by a hundred bucks or more.
<STRONG>But Novak is even cheaper than AA by a hundred bucks or more.
</STRONG>
Look at a thread called the "YJ so far" by yjtj member #3385 he's running your combination. He should able to tell you something.
<IMG SRC="smilies/blender.gif" border="0">
The adapter from the TH350 to an NP208 from mid to late 80's chevy trucks will bolt up the D300. All you have to do is find out the spline count on your tranny and get a new input gear for the Dana 300, unless you get a TH350 with a 23 spline output shaft then they will bolt right up.
What gears are you planning on running and how much power is the 350 putting out, because a TH700R4 may be a better choice for getting the crawl ratio down a little bit. If the 350 is less than 300 horses the R4 will handle it with no problem. The adapter also came on the R4's so bolting it up won't be a problem. You will need to get a new input gear though.
Hope this helps <IMG SRC="smilies/smile.gif" border="0">
did somebody say my name. yah im running that combo i used an aa adapter and redrilled it so i could clock the d300 and use a flat skid. i also upreaded to a 32 spline output from them. i am gonna run 1350 u jionts in a high angle drivelines d shaft when i get my lazy but to order it. heres
the thread with pics.
http://www.pirate4x4.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic&f=4&t=006107
1 - 8 of 8 Posts
