1 - 4 of 4 Posts
Has anyone here found a good source for 3500 unit bearing on a 97' ?
I have some 2500 bearings and plan on buying 3500 version I I can't find someone that wants to swap.
What else will I need to turn a 2500 axle into a 3500 axle?
I'm not sure there is a difference in the bearings. The only difference is the adapter for the dually wheel as far as I know.
Ebay had them for 125ish each last year, but not sure if they are still on there or how much. I got mine from NAPA with a 2 year warranty for $530 for two, but I have the ABS stuff, I think the non ABS ones are a lot cheaper.
There the same as the 2500's. Just a dually adapter is used up front on the dana 60. So go ahead and use them.
1 - 4 of 4 Posts
