1 - 11 of 11 Posts
mine are about 75%tread and measure 36 in tall on hummer rims with 15 psi in them
Which height are you looking for exactly?
Unmounted?
Mounted on an 8" wheel?
Mounted on a 10" wheel?
Under the weight of a 3500 lb rig with full pressure?
Under the weight of a 3500 lb rig with trail pressure?
Under the weight of a 5300 lb rig with full pressure?
Under the weight of a 5300 lb rig with trail pressure?
New?
Worn?
Since swampers can vary up to an inch in the same size designation the numbers you get might not help all that much.
:flipoff2:
· Premium Member
Thanks I will clarify, I don't really care what size rim at this point as they have not been bought, I would guess though on an 8in. The background of the situation is that I want to run 37" tires but would also rather run a 36" sx over a 37 mtr. I would love a set of Krawlers but dont have the bling. Then i heard that a 38x12.5 sx runs small. If it does in fact run closer to 36-37"; I am going to run a 38x12.5 sx!
mine brand new 38x12.5 sx measure 36.75" tall on a 15x8 rim with 20psi unloaded....
my buggy wieghs 3k....dont know yet how tall they are when loaded
1 - 11 of 11 Posts
