1 - 5 of 5 Posts
one of the guys on the board told me he had a 3in spacer block that would fit my d44 knuckle. i already have a 1in stepped up roggy arm and i think i will need morelift to the steering arm. is a 3in block safe amd where do i find studs that long? or do i need to use bolts for this application?
<IMG width=404 height=288 SRC="http://www.pirate4x4.com/ubb/uploads/3inchblock.JPG">
when i was running the d44 i had to use the 3 inch blocks. needed them cause i had 4 inch springs soa and ran the d link over the arm and the tie rod under the arm, but everything over the spring. never had any probs with it. i used 3 inch chevy steering blocks from bds and they came with the studs
1 - 5 of 5 Posts
