1 - 10 of 10 Posts
Tell me what you guys think. This is for a front end. 3link wishbone style with the wishbone as bottom link and mounted on the inboard of the frame and the top links mounted on the outboard off the frame using the same bolts as the bottom link just sleeve the frame. Top links mounted at the axle with like a 6” spread off the bottom mount. Links would be Johnny joints on all links both ends except frame side of wishbone which would be bushings. on paper it looks good, no extreme pinion angles. It would be easy to setup, protect front driveline and oil pan. But how do you think it would handle and would this same set up work as a rear suspension?
your roll axis is at the angle of your lower links, at the height of the wishbone convergence
you have infinite as/dive right now, need seperation, at least i would if it were mine
its also really easy to draw something...to actually get it to fit on the vehicle like that with an oil pan, frame rails, shocks, springs and steering is a completely different story............qyuit drawing pics and go throw some broomsticks under your truck to see what REALLY works
mines nothing like my pictures...itw a sereis of comprimises for fit, clearance and, hopefully, performance on the street and trail
1 - 10 of 10 Posts
