1 - 20 of 21 Posts
I got this v-6 third from another member a while back, it was one that was setup by a toyota tech, so I don't doubt that it was done properly, but I want to see if I am over reacting to something that is common, or if something is getting loose.
I was replacing the passenger birfield yesterday and while putting the hub back in I turned the rotor to line something up and noticed that the pinion flange pushed outward (compressed the drive shaft about 1/2" at most). So I did it several times and notice that it made no difference which way I turned the rotor, it still jumps out every time.
Generic picture, my problem is on the front axle
FWIW, v-6 third with a detroit locker, 5.29's, solid spacer
does that make sense to anyone? ideas on a repair?
Don't drive it until it gets fixed. If torqueing the pinion nut doesn't fix it, then she has to come apart. If the pinion gets tight and has serious resistance to turn within it's lash, then it should come apart as well.
Use a brand new nut, red/green loctite on oil free threads, and make sure to stake it when you are done.
Discussion Starter · #9 ·
i pulled it all apart (probably a bad idea since i have no idea about adjusting backlash, but suppose i will take it somewhere). there is no space between the bearing and the pinion gear teeth. possibly the bearing slid up on the shaft and allowing the movement?
Discussion Starter · #11 ·
sure thing
this is what it looks like when i took it out. the gear, a washer, a small spacer, the rear bearing, another washer, a shim, the solid spacer, and 8 more shims.
close up
Discussion Starter · #12 ·
im thinking that the front bearing may have backed off. the stake nut threads are a little worn (that may have been my problem all along. i am heading to town to see if i can find a replacement.
Discussion Starter · #14 ·
i originally thought it had moved. now i am beginning to think that the nut backed off and is allowing a little slack in the pinion. my theory was going great until I stripped out the inside of the stake nut. now i cant find a replacement. the only local parts store we have cant find one (they carry a castle nut for a GMC, but it is too small) and the toyota place is closed. :(
Unless you need the truck running that bad, I would wait for the right nut.
Too bad you aren't here in fresno, I have a spare.
X2
dont use the wrong nut. thats not going to help anything. But i'm sure if you ask some other toyota guys around town, somebody is bound to have one. i know i've got a handful in the garage, and so do my friends. so ask around....
and on another note, on these toyota third members you adjust the backlash with the adjuster rings that put pressure on the carrier bearings. hopefully you marked them as to placement and which side they go to. that way when you put it all back together, it should be pretty much within spec. if not your going to need a dial indicator and a mag base. you can get them for cheap at harbor freight. like $25 for both.
these links may help.
the pirate gear bible
zuk- gearinstalls.com- all toyota gear installs...
sure thing
close up
That looks like a bunch of preload shims on that spacer. What do they measure?
Front pinion bearing must be bad, or I screwed it up when I built it :confused:
Lemme grab a new bearing and seal, there is only one shim under the "big" bearing to set the pinion depth...the "big spacer" is actaully the pinion bearing inner race.
I'll come out there and put 'er back together..See Ya' Wednesday
1 - 20 of 21 Posts
