1 - 4 of 4 Posts
Does anyone know if I can take an Injected 4.3 (Late 90's?) and put on an early 4.3 intake? Are the angles and sizes the same?
Thanks
If you have TBI heads you can if you have vortec heads you cant.
Ive got a 86 model 4bl intake on my 97 Vortec motor. I grinded the rivets off that hold the heat sheild on the bottom of the intake. Haven't had any clearence problems with the balancing shaft(or whatever its called) Most people want to see it after I tell them what I got <IMG SRC="smilies/smokin.gif" border="0">
Did you have to grind the heat shield? Did you encounter any other problems? Do you like the 4.3?
Thanks,
1 - 4 of 4 Posts
