1 - 2 of 2 Posts
I tried this in nonhardcore but didnt get a response so i figured id try my luck here
I searched around but didnt find what i was looking for. Im in need of info on swapping a chevy 4.3 TBI into my YJ. im starting with a bare frame and tub and building from there. Trails only so street legality is not an issue. I wont be using the JEEP harness at all soo getting the two to work together is not an issue and ill be using a custom dash and gauges. basically all I am looking for is how to get the motor wired to run. I have the full chevy harness and computer. Im hoping someone can point me in the right direction as to where i can find info on wiring this motor To run and what uneccessary components can be removed from the harness and motor(emissions stuff??).
any help would be greatly appreciated
btw i believe the motor is from a 1990 s10 and im planning on using either a th350 or 700r4
Thanks
steve
You'll probably need to get you CPU re-flashed. Jim's Performance seems to have a good reputation on this board. He can rework the harness, removing what you don't need, as well.
I haven't got to the wiring on my project yet, so I can't give much more info.
Good luck with your Jeep.
Matt
1 - 2 of 2 Posts
