1 - 20 of 21 Posts
Be careful that the wheels are rated for the rpm. They will still throw wires, but not quite as bad. Many that will fit the grinder are rated for much less.
Banned
The wire cup I have has the braided lines, so they're kinda tied into bunches. I think it holds the wires better, and it's great for heavy stuff (it acts like a few really fat wires, rather than hundereds of skinny ones).
ABSOLUTELY. Don't even mess with the wire cups. Go stright to the braided or twisted type thing where they're in clumps. They'll last more than 10x longer. It'll also save you time changing cups and stick a lot less wires in your crotch.
Discussion Starter · #8 · (Edited)
Lowe's had the stray wire cups or the braided flat wheels. I got one cup to try it, pretty awesome, compared to the old fasioned way. It does throw some wire though, hurts too. I think this one cup will do a whole front axle, I just spent 10 minutes on the inner C and the long side tube.........all clean now.
I didn't see any braided cups.
Pazuzu, who makes the braided cups? Lowes only carries DeWalt. I may need to go elsewhere.
Try Airgas "used to be County Welding and now across the street"
Carefull the greasy wires can give you a tatoo when they stick, or so I have been told. I have not gotten one from it though.
The worst is when they stick in you pants make it through the wash then tear your leg when you put them back on.
i used to use a wire cup in a cordless drill with some carb cleaner to clean off my honda transmissions. worked beautifully. gave it a near polished shine. after a bit of dust settled it wasn't so shiny, but still a lot cleaner then the greasy pos it was...
Banned
Sadly enough I still have the empty package laying around :eek:
Milwaukee, "Knot Cup Brush", part # 48-52-5040 for 5/8-11 spindle.
I'm 99% sure it came from Home Depot, because that's the only place I shop for stuff like that.
We used the wire wheel on the grinder this past weekend to clean up an old 9" - worked awesome. It wasn't the "Cup" style, but a flat style like a wheel with wires. It was a cheepo, and all the wires were missing at the end, but it did a fantastic job. Goggles/face shield a must :p
Discussion Starter · #16 ·
Ah, okay thanks. I'll try Orchard, they sell Milwaukee, Home Depot is a PITA here.
Found a couple wires in my pants this morning on my way to work, yeouch!
safety goggles of course a must. I don't even do a quick touch up with any sort of wire wheel without them on even if I am just running it for a second. When I was doing my front axle after I got it from the junk yard I definately came in one time and looked in the mirror and had a wire sticking directly in the tip of my nose. It was lodged pretty damn deep too. Whenever I use one I always have like a million wires stuck in my jeans...
Moderator
Doug, I would definitely be careful or the hgh RPM tool. They will definitely come off, and I already got one on my neck before using an air type drill. kinda hurt my neck, so I am very careful.
I almsot lost my thumb on the sawzall, so I learned my lesson well. Extra extra protection, specially ey protection.
Gui
1 - 20 of 21 Posts
