1 - 20 of 37 Posts
What I'm thinking is since the TJ dana 44 and the XJ rearend are the same width why not use the more common TJ 44? Sure I could just cut off the coil buckets and the control arm mounts. But why do that when I could just use those mounts and make a custom long arm 4 link. This would use coil springs. So the question is what is the spring rate of the 6" skyjacker XJ front coils? Since I would like the front and rear to be as balanced as possable would the rear spring rate need to be lower since they dont support the weight of the engine and tranny? I just thought of this and its 5am so I havent really thought it through. This is just a mild rig so I'm not looking at 60's that will be on my next rig. So am I <IMG SRC="smilies/rasta.gif" border="0"> ?
[ 10-17-2001: Message edited by: Eddie Mcstiff ]
[ 10-22-2001: Message edited by: Eddie Mcstiff ]
You're gonna find that TJ 44's are really expensive. A typical axle will run you around $800 - $1000. Just a plain housing is $750 from a dealer. Think about an axle from a Waggy or a Scout if you want a 44. If you want a bigger axle, why not an 8.8? You can get one of those for around $400 off an Exploder.
Originally posted by Jim M:
<STRONG>You're gonna find that TJ 44's are really expensive. A typical axle will run you around $800 - $1000. Just a plain housing is $750 from a dealer. </STRONG>
I know a pick and pull in CO where all rearend assemblies are $52.95 and housings are $22.95, This is for any make and model. I'm now planing on doing this too soon so I have time to find a rearend.
<STRONG>If that is true and they have TJ 44's, get ALL of them. Get every one they ever get in. Ship them to me at my cost and I will sell them and pay you 1/2 the profits.</STRONG>
They get in 200 cars a week. Sorry I'm from the right cost I would prob. have others higher on the list than you. <IMG SRC="smilies/biggrin.gif" border="0">
<STRONG>Well, I had to try...</STRONG>
Ya never know unless you do <IMG SRC="smilies/biggrin.gif" border="0">
XJ D44's seem to be plenty common here in MN. Guys in my club found 3 at the pick and pull in the last few weeks. On the other hand, the TJ D44's are pretty rare, and expensive.
Discussion Starter · #11 ·
Originally posted by Matt R.:
<STRONG>Yo Eddie,
Where is that pick n pull in CO?
I'm up in Longmont</STRONG>
PM'd ya. ttt
According to the quality sources at JP ragazine, late model 44's, such as those found in TJ's use a thinner axle tube as compared to earlier 44's. Unless you really want to use all of the TJ bracketry, it may be worth your while to hunt for an older/stronger 44 or something else altogether.
cm "keep a mindful eye and you may see a TJ 44 fall off a truck" k
Discussion Starter · #13 ·
I have been thinking about this. The main problem is width and lug pattern. Since I think I'm going to have the rig regestured in PA I cant be sticking out past the fender flairs. So I dont want to go any narrower than 60" but wider is pritty much out of the question too. This might change since I'm going to be in Colorado for a while and I like the law's better here. I think i'm going to be keeping the D30 and trussing it. This will give me a 5 on 5.5 (warn hub kit) and I would like to keep that. I could always make a housing to fit 60" D44 axle shafts.
Discussion Starter · #14 ·
Well I just looked at a TJ and i dont like the linkage design. I want to make a "double V" 4 link not unlike desertoy has on his buggie. So I guess I could use any dana 44 But I'm going to try to find one from a MJ or a XJ to keep the fab work down. Looks like I was <IMG SRC="smilies/rasta.gif" border="0"> at 5 am. <IMG SRC="smilies/biggrin.gif" border="0">
[ 10-18-2001: Message edited by: Eddie Mcstiff ]
hey, I know of pull-n-save on peoria and 225/I-70, but their prices are $67 per axle...which one do you go to?
Yo Big Eddie,
That one that Mike said is the same one you're talking about, and axles are 67 after core charge. You missed out this weekend though, because everything was half off, and they had free hot dogs on Sunday. Can't beat a $35 axle.
~Scott
Discussion Starter · #19 ·
Yeah, so if you give them your axle then you get the 10 spot back <IMG SRC="smilies/biggrin.gif" border="0"> . I wish I had known about the half price weekend, I need a new t-case. Dammit.
1 - 20 of 37 Posts
