1 - 15 of 15 Posts
I recently did a three way trade and got this. Don't need to sell, but I could use the cash to finish another build I've got. So
84 Ford Bronco from the south. No rust, or rust repairs, ever. Some trail dents.
Mild built 460
-edelbrock performer cam
-edelbrock rpm intake
-dove heads with gasket matched port job
-gasket matched exhaust with l&l lifetime headers w/ 1-7/8" primaries
-holley 750 double pumper w/ mechanical secondaries
-Billet hei distributor
*All info with these parts put this motor somewhere in the 400+ hp range*
Coan built C6 with 2600 stall
Borg Warner transfer case
Straight axle conversion with a HP Reverse rotation Dana 44, 4.11 gears, coil springs w/extended radius arms and heim joints, one ton steering parts. Also has warn lockouts on it.
Rear is a Ford 9", detroit locker, 4.11 gears,
*Both axles came from 78 or older Bronco*
Custom Roll cage fits nicely under the removable top
Custom front and rear bumpers with 2" receivers. Front has shackle brackets and winch mount.
One ton brake booster, power steering pump
37x14x15 Bias Ply Iroks in good shape on Aluminum wheels
power windows, locks
If you want specific pics let me know.
I can be reached on the site here or by cell phone. 810-691-3805.
Looking for $6000obo/may trade for fullsize 3/4 or one ton crew cab
Located in Mid-Michigan, Flushing to be exact. 48433
Used to look like this
1 - 15 of 15 Posts
