I should be able to get one off a chev 1 tonne. There is a mob close that imports spares from the US so I will try them.
As far as progress I got lots to do. Just putting the drive train together ATM. Its a 302 Windsor, NP435, NP205. All sitting on the floor. Just setting up the ancilleries on the motor, do the twin stick mod to the np205 and it should be good to bolt together. Then Im going to sit the front axle under the motor and have a look where it will fit and I probably will cut and shut the 302w sump to give better clearance cause I really want this thing as low as I can get it (which will still be quite high I think). Im thinking that the centre of the front axle line will be about 10inches in front of the front motor pully. I want to run baout 112in WB so I do need to check how the rear DS lenght is going also.
Then for the mogs i got to do the pinion conversion. ATM they have the torque tubes and tailshafts so there is a bit of work to do there. Got to machine the drums for the 15in wheels and get some wheel centres laser cut to convert my 15s to mog pattern.
Once this is done throw the whole lot into a disco frame that I got and slap my current body back on with a new roll cage (got to build this as well).
Want to get it going by the 22 March for a comp so I will see how I go.
Sam
404axzlSpch
