1 - 8 of 8 Posts
cruiserrg said:
You need to press it out. Make sure to keep all the needle bearings, and watch the rubber seals when pressing.
Press - bugger - haven't got one of them at home :(
Any idea many tons I'll need - typically.
Someone has been in there before, the rubber seals are knackered, and some of the needle bearings lost already :mad3:
you might get by with a 25 ton press but I can say from doing mine that a 50 might be needed
the pins came out easy but going into the new shafts (narrowed axle) took a lot more force
press would work but difficult to position in a press. go to harbor freight and get a ball joint press. It looks like a big c clamp with a hole in it. tighten the threaded side and the cross shaft will slide out through the hole in the other side. They were under 40.00 last time I was at harbor. works good. while you are at it you might replace the seals inside of that cv. I got some seals from teradon
1 - 8 of 8 Posts
