I have pulled a few of these early 70s 413 motor home engines. I wanted them for the forged cranks, which are the same as the 440. After reading the thread on the 413 HD on the scout board, I feel I should comment on the crank stroke issue. Someone mentioned that the industrial 413 had a 3.70 stroke crank as adversed to the automotive 3.75 stroke crank. Perhaps these shorter stroke cranks are the ones with eight bolt holes in the flange that I have heard about??
Be aware that there are other industrial 413s that do not have this shorter stroke crank, but have the regular 413/426/440 six hole crank and the standard LY rod (non six pack). they still have the strange heads with direct water passage to each head. These heads use a different exhaust manifold than the regular heads, but the intake appears to be the same (not positive though). I have seen three of them like this now.
I primarily wanted them for the steel cranks which are worth some money. And also to use a crank in a 400 block that's lying here... (not for a truck motor though, for a high rpm muscle car screamer). but after checking out these super beefy blocks, i may use a 413 with some 452 heads for a truck engine!
