1 - 4 of 4 Posts
416 pinion conversion started
had some time for my rig today.
started to make pinion conversion to it:D
i noticed that pinion splines and outside wasn`t centered:(
i had to center it from splines and cut to the next seal size 55mm :cool2:
machined centering and weld grooves to flange and spline part
after welding machined them some more.
tomorrow i hope i can machine flanges to fit toyota dshafts and make torguetube parts:D
Discussion Starter #2 (Edited)
driled and machined pinions flanges to toyota dshafts and made the torg tubes.
in the flange spline lenght is 65mm (2.56") and torguetube part is 170mm
(6.69") long.
seal size is machined to 55x90x8mm and has room for 2 seals:smokin:
i made this step behind the flange, it locks the nut
testing the assembly to my spare pinion parts:D
and it looks like this in my buggy
thhhpptthh!
badass. exactly what i had in mind for mine. just finished picking up the parts i needed and hopeing to get some work in on the lathe in the next few weeks :D
1 - 4 of 4 Posts
